2020 ADSB Compliance
#11
At this stage its looking like over here in NZ they are going to allow the TABS GPS unit from MGL with TSO-C199 standard, the MGL SP-12, which is quite well priced and has been confirmed to work with the Trig transponders.
Gary
XE285 in NZ
#12
Based on the info that was supplied this is the best option I have found to date that will allow the use of the Trig TT-21. I will continue to look for other options and hope you all will do the same. Thanks!
https://uavionix.com/products/tailbeacon/
Michael
XE 285  1205 (Myrtle)
Start: 8/1/2013
Finish: 5/24/2014
Arrived home: 10/11/2014
#13
(04-17-2019, 02:35 AM)FlyGuy Wrote: Based on the info that was supplied this is the best option I have found to date that will allow the use of the Trig TT-21. I will continue to look for other options and hope you all will do the same. Thanks!
Michael
I read on the VAF forum that Trig will upgrade your TT21 to a TT22 for $950. Add to that their TN72 and TA50 GPS antenna and you'd be close to the cost of the TailBeacon.
RV-7A builder/owner
WannaBe Mosquito builder
#14
The reason I mentioned it for you guys to investigate in the US is because the TABS GPS comes in a lot cheaper, probably about $500 in USD or just over $700 over here in NZ (thats with the Antenna included, that the Trig TN unit needs to have purchased separately).
https://www.mglavionics.co.za/sp12.html
Gary
XE285 in NZ
#15
Michael
Start: 8/1/2013
Finish: 5/24/2014
#16
ADS-B Information that may save you $. Class 1 Transponder is required.
https://youtu.be/U6Z9zRzX0qE
Michael
Start: 8/1/2013
Finish: 5/24/2014
